Quest
February 13, 2024, 1:59pm
1
I’m getting this error when packaging my project in Unreal.
there’s a bit more to the errors but I didn’t want to overload the chat here.
was hoping I could get some help here.
I removed the access tokens.
UATHelper: Packaging (Windows): LogCesium: Error: [2024-02-13 06:09:08.222] [error] [ErrorList.h:72] Errors when loading tileset:
UATHelper: Packaging (Windows): - Received status code 401 for asset response https://api.cesium.com/v1/assets/1/endpoint?access_token=
UATHelper: Packaging (Windows): - Received status code 401 for asset response https://api.cesium.com/v1/assets/96188/endpoint?access_token=
UATHelper: Packaging (Windows): LogCesium: Error: [2024-02-13 06:09:08.222] [error] [RasterOverlayCollection.cpp:127] Assets used with a raster overlay must have type ‘IMAGERY’, but instead saw ‘unknown’.
UATHelper: Packaging (Windows): - Received status code 401 for asset response https://api.cesium.com/v1/assets/354307/endpoint?access_token=
UATHelper: Packaging (Windows): ERROR: Cook failed.
PackagingResults: Error: Unknown Cook Failure
I’m not sure if it’s related but I also get an error when I build the lighting:
=== Lightmass crashed: ===
Assertion failed: (Index >= 0) & (Index < ArrayNum) [File:D:\build++UE5\Sync\Engine\Source\Runtime\Core\Public\Containers\Array.h] [Line: 752]
Array index out of bounds: 969 from an array of size 969
0x00007ff78bb99af3 UnrealLightmass.exe!Lightmass::FStaticMeshLOD::GetIndex()
0x00007ff78bb9af9d UnrealLightmass.exe!Lightmass::FStaticMeshStaticLightingMesh::GetTriangleIndices()
0x00007ff78bb0b3c9 UnrealLightmass.exe!Lightmass::FEmbreeGeometry::FEmbreeGeometry()
0x00007ff78bb1516a UnrealLightmass.exe!Lightmass::FEmbreeAggregateMesh::AddMesh()
0x00007ff78bb6a8f0 UnrealLightmass.exe!Lightmass::FStaticLightingSystem::FStaticLightingSystem()
0x00007ff78bb1bd71 UnrealLightmass.exe!Lightmass::BuildStaticLighting()
0x00007ff78bb410eb UnrealLightmass.exe!Lightmass::LightmassMain()
0x00007ff78bb63410 UnrealLightmass.exe!main()
0x00007ff78bbd16cc UnrealLightmass.exe!__scrt_common_main_seh()
0x00007ffda1257344 KERNEL32.DLL!UnknownFunction
0x00007ffda29826b1 ntdll.dll!UnknownFunction
Quest
February 13, 2024, 2:31pm
2
I also notice that most of these are 401 errs but one stood out which was a 400:
UATHelper: Cooking (Windows): LogInit: Display: LogCesium: Error: [2024-02-13 07:13:32.694] [error] [ErrorList.h:72] Errors when loading tileset:
UATHelper: Cooking (Windows): - Received status code 400 for tileset https://tile.googleapis.com/v1/3dtiles/root.json?key=
Quest
February 13, 2024, 2:33pm
3
perhaps is this because I should be using cesium ion instead of from url?
I’m not quite sure the difference but it seemed like it could be related.
Quest
February 14, 2024, 12:13am
4
here are some errors I get when cooking the project:
UATHelper: Cooking (Windows): LogInit: Display: LogCesium: Error: [2024-02-13 16:22:26.074] [error] [ErrorList.h:72] Errors when loading tileset:
UATHelper: Cooking (Windows): - Received status code 404 for asset response https://api.cesium.com/v1/assets/354307/endpoint?access_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiIxYTgyZjFjMy03ZTc3LTQ2NWEtYTUxYi0yYjlmMWQ5NmYyNTUiLCJpZCI6MTgxMDc4LCJpYXQiOjE3MDExMDk5NTJ9.7V_rGNP7baSqeK13W6zZJBj7DpUP19v9bXk1nUFz-4g
UATHelper: Cooking (Windows): - Received status code 404 for asset response https://api.cesium.com/v1/assets/5713/endpoint?access_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiIxYTgyZjFjMy03ZTc3LTQ2NWEtYTUxYi0yYjlmMWQ5NmYyNTUiLCJpZCI6MTgxMDc4LCJpYXQiOjE3MDExMDk5NTJ9.7V_rGNP7baSqeK13W6zZJBj7DpUP19v9bXk1nUFz-4g
UATHelper: Cooking (Windows): LogInit: Display: LogCesium: Error: [2024-02-13 16:22:26.075] [error] [ErrorList.h:72] Errors when loading tileset:
UATHelper: Cooking (Windows): - Received status code 404 for asset response https://api.cesium.com/v1/assets/43978/endpoint?access_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiIxYTgyZjFjMy03ZTc3LTQ2NWEtYTUxYi0yYjlmMWQ5NmYyNTUiLCJpZCI6MTgxMDc4LCJpYXQiOjE3MDExMDk5NTJ9.7V_rGNP7baSqeK13W6zZJBj7DpUP19v9bXk1nUFz-4g
UATHelper: Cooking (Windows): - Received status code 404 for asset response https://api.cesium.com/v1/assets/16421/endpoint?access_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiIxYTgyZjFjMy03ZTc3LTQ2NWEtYTUxYi0yYjlmMWQ5NmYyNTUiLCJpZCI6MTgxMDc4LCJpYXQiOjE3MDExMDk5NTJ9.7V_rGNP7baSqeK13W6zZJBj7DpUP19v9bXk1nUFz-4g
UATHelper: Cooking (Windows): - Received status code 404 for asset response https://api.cesium.com/v1/assets/75343/endpoint?access_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiIxYTgyZjFjMy03ZTc3LTQ2NWEtYTUxYi0yYjlmMWQ5NmYyNTUiLCJpZCI6MTgxMDc4LCJpYXQiOjE3MDExMDk5NTJ9.7V_rGNP7baSqeK13W6zZJBj7DpUP19v9bXk1nUFz-4g
UATHelper: Cooking (Windows): - Received status code 404 for asset response https://api.cesium.com/v1/assets/354759/endpoint?access_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiIxYTgyZjFjMy03ZTc3LTQ2NWEtYTUxYi0yYjlmMWQ5NmYyNTUiLCJpZCI6MTgxMDc4LCJpYXQiOjE3MDExMDk5NTJ9.7V_rGNP7baSqeK13W6zZJBj7DpUP19v9bXk1nUFz-4g
UATHelper: Cooking (Windows): - Received status code 404 for asset response https://api.cesium.com/v1/assets/69380/endpoint?access_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiIxYTgyZjFjMy03ZTc3LTQ2NWEtYTUxYi0yYjlmMWQ5NmYyNTUiLCJpZCI6MTgxMDc4LCJpYXQiOjE3MDExMDk5NTJ9.7V_rGNP7baSqeK13W6zZJBj7DpUP19v9bXk1nUFz-4g
UATHelper: Cooking (Windows): LogInit: Display: LogCesium: Error: [2024-02-13 16:22:30.165] [error] [ErrorList.h:72] Errors when loading tileset:
UATHelper: Cooking (Windows): - Received status code 400 for tileset https://tile.googleapis.com/v1/3dtiles/root.json?key=AIzaSyCnRPXWDIj1LuX6OWIweIqZFHHoXVgdYss
UATHelper: Cooking (Windows): LogInit: Display: LogCesium: Error: [2024-02-13 16:26:33.414] [error] [ErrorList.h:72] Errors when loading tileset:
Those errors make me think your level is simply misconfigured. Especially this one:
Those errors pop up while it’s cooking a particular level, presumably. Can you try opening that same level in the Editor and see if you get similar errors? If so, and you’re not sure how to fix it, share how the Cesium objects in your level are configured.
Quest
February 22, 2024, 11:44am
6
just replying here to show that the issue was resolved in another thread:
I followed link below and it cooks!
I think I can get to the OSM Buildings later but for now let me test some things and I will get back to the thread.
Generally I would rather use Google’s keys because Ion’s buildings are not as high-quality. But I get far more errors when I go that route.
I’ll be back haha.
