i was package my project then this happened. can anyone tell me how to fix it please?
UATHelper: Packaging (Windows (64-bit)): Creating Staging Manifest…
UATHelper: Packaging (Windows (64-bit)): ERROR: System.Exception: Couldn’t update resource
UATHelper: Packaging (Windows (64-bit)): at ModuleResourceUpdate.SetData(Int32 ResourceId, ResourceType Type, Byte Data) in D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\Win\WinResources.cs:line 265
UATHelper: Packaging (Windows (64-bit)): at ModuleResourceUpdate.SetIcons(Int32 ResourceId, GroupIconResource GroupIcon) in D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\Win\WinResources.cs:line 270
UATHelper: Packaging (Windows (64-bit)): at BaseWinPlatform.StageBootstrapExecutable(DeploymentContext SC, String ExeName, FileReference TargetFile, StagedFileReference StagedRelativeTargetPath, String StagedArguments) in D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\Win\WinPlatform.Automation.cs:line 153
UATHelper: Packaging (Windows (64-bit)): at BaseWinPlatform.GetFilesToDeployOrStage(ProjectParams Params, DeploymentContext SC) in D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\Win\WinPlatform.Automation.cs:line 103
UATHelper: Packaging (Windows (64-bit)): at Win64Platform.GetFilesToDeployOrStage(ProjectParams Params, DeploymentContext SC) in D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\Win\WinPlatform.Automation.cs:line 570
UATHelper: Packaging (Windows (64-bit)): at Project.CreateStagingManifest(ProjectParams Params, DeploymentContext SC) in D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\Scripts\CopyBuildToStagingDirectory.Automation.cs:line 751
UATHelper: Packaging (Windows (64-bit)): at Project.CopyBuildToStagingDirectory(ProjectParams Params) in D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\Scripts\CopyBuildToStagingDirectory.Automation.cs:line 4217
UATHelper: Packaging (Windows (64-bit)): at BuildCookRun.DoBuildCookRun(ProjectParams Params) in D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\Scripts\BuildCookRun.Automation.cs:line 216
UATHelper: Packaging (Windows (64-bit)): at BuildCookRun.ExecuteBuild() in D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\Scripts\BuildCookRun.Automation.cs:line 39
UATHelper: Packaging (Windows (64-bit)): at AutomationTool.BuildCommand.Execute() in D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\AutomationUtils\BuildCommand.cs:line 263
UATHelper: Packaging (Windows (64-bit)): at AutomationTool.Automation.Execute(List1 CommandsToExecute, Dictionary2 Commands) in D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\AutomationUtils\Automation.cs:line 547
UATHelper: Packaging (Windows (64-bit)): at AutomationTool.Automation.Process(String Arguments, StartupTraceListener StartupListener) in D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\AutomationUtils\Automation.cs:line 511
UATHelper: Packaging (Windows (64-bit)): at AutomationTool.Program.MainProc(String Arguments, StartupTraceListener StartupListener) in D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\Program.cs:line 175
UATHelper: Packaging (Windows (64-bit)): at AutomationTool.Program.<>c__DisplayClass1_0.b__2() in D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\Program.cs:line 87
UATHelper: Packaging (Windows (64-bit)): at AutomationTool.InternalUtils.RunSingleInstance(Func`1 Main) in D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\AutomationUtils\Utils.cs:line 739
UATHelper: Packaging (Windows (64-bit)): at AutomationTool.Program.Main(String Arguments) in D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\Program.cs:line 87
UATHelper: Packaging (Windows (64-bit)): (see C:\Users\Admin\AppData\Roaming\Unreal Engine\AutomationTool\Logs\C+Program+Files+Epic+Games+UE_4.27\Log.txt for full exception trace)
UATHelper: Packaging (Windows (64-bit)): AutomationTool exiting with ExitCode=1 (Error_Unknown)
PackagingResults: Error: System.Exception: Couldn’t update resource
UATHelper: Packaging (Windows (64-bit)): BUILD FAILED
PackagingResults: Error: Unknown Error
Hi @iv1,
I haven’t seen an error like that. As a total guess, maybe check for files in the package output directory that are marked read-only or that are open in another problem. Nothing in there is obviously Cesium related, so does it happen even when the Cesium plugin is disabled? It could be worth asking your question on a more general Unreal Engine forum.
Kevin
