I have the Google API key & the API key from Cesium but when ik copy and paste them together I don’t see de world loading Does anyone know what to do
ik normally use a VM but I took this screenshot from my low-performance laptop
It looks like you’re using an “Empty Open World” template. Just use the Empty template. Those assets in the foreground might simply be blocking the globe behind it.
Also, make sure that “Realtime” mode is enabled. It’s on the hamburger menu at the top left of the viewport, and UE automatically turns it off if you open the project from any sort of remote desktop solution. And then it stays off even if you switch back to local use.
I’d recommend starting with the Cesium for Unreal Samples project, which can be download with the Epic Launcher. That will help eliminate any possible problems introduced while following the tutorials.
