I am having issues with the 2D (and 3D) Bing map looking stretched and low resolution. It barely resembles the original Bing map in terms of style and quality. There also seem to be some kind of perspective on the camera in 2D mode, in other words its not straight above the map which I want it to be.
Running the following code in Sandcastle will demonstrate the issue:
sceneMode : Cesium.SceneMode.SCENE2D
I wanna fix this because I want the map to look fairly crisp and I need the labels of cities etc on the map to be clear and easy to read. I am open to try another kind of map but I need one without satellite imagery, I just want a clean white map. I have looked at other peoples threads with similar issues but I have not found a working solution. I tried bumping up the screenspaceerror to 1.33 in 3D mode but that lead only to a minor improvement. Anyways I need a fix applicable to 2D aswell.
I am running Cesium version 1.59.0 in Chromium (ionic webview).
Thanks!
