I am trying to run Cesium on a multi-node nDisplay setup on 3 Windows PC’s. From what I’ve been reading on other posts, it sounds like the plugin should work, but whenever I try bringing it up on the listener nodes, they crash every single time. The workstation (editor) node works fine every time.
I have deleted all but one token, so I know for fact that all PC’s are using the same one across the board. I want to be able to use the “Google Photorealistic 3D Tiles,” but as mentioned before the listener nodes crash every time. I even created a blank level without any of the Cesium assets inside that particular level and it still ended up crashing.
It is worth noting that I am using a “CesiumPolygonRasterOverlay” to cut out a specific section that I want to stream. I have also designated the “Georeference”, “Credit System”, and “Camera Manager”. I am using “From Cesium Ion” as the source of the data.
My main question is whether there is something missing in my workflow that I need to make it to where the everything will stream properly through nDisplay on a multi-node setup?
Thank you in advance for your help.
Hey @granterdoes, welcome to the forum! Multi-node nDisplay setups can definitely be tricky with Cesium, lots of topics on the subject.
We’ve seen nDisplay + Cesium crash issues in prior threads, and the resolution has varied. A few things worth checking:
Clean plugin install – in a prior thread, a similar crash was resolved by doing a clean reinstall of the Cesium plugin on all nodes, making sure every machine has the exact same plugin version. Even minor version mismatches between nodes can cause crashes.
Crash log – could you share the full crash log from one of the failing listener nodes? It’s usually in Saved/Crashes/ or the Output Log. The call stack is the most useful piece for narrowing down the cause.
Does it crash with or without a Cesium tileset in the level? You mentioned it crashes on a blank level – does that blank level still have a Cesium3DTileset actor, a CesiumGeoreference, or a CesiumCreditSystem? If removing all Cesium actors from the level stops the crash, that helps isolate the problem.
Network access – all listener nodes need direct network access to api.cesium.com and the tile CDN. A firewall or proxy blocking those endpoints would cause failures at startup.
Since you’re on UE5.5, the TinyXML2 conflict that caused crashes in earlier versions (#38323) should be resolved, but the crash log will confirm. You could also try a more recent version of Unreal, but UE5.5 is still supported by Cesium for Unreal (but to be clear, nDisplay is not officially supported)
Let me know how that goes!
