hello!
First of all, thank you very much for seeing my question.
I use ScreenSpaceCameraController enableRotate/enableTilt/enableTranslate properties of lens events spin, tilt, translational control.But the effect was deranged.The result is that the enableRotate attribute controls the translation of the camera, the enableTilt attribute controls the tilt and rotation of the camera, and the enableTranslate attribute does not work.
So I would like to ask what went wrong?
thank you so much!!
var scene = viewer.scene;
scene.screenSpaceCameraController.enableRotate = false;
scene.screenSpaceCameraController.enableTilt = false;
scene.screenSpaceCameraController.enableTranslate = false;
I want to control the tilt of the camera to a certain extent.
I use the 1.41 version of cesium and the 63.0.3239.84 version of the google chrome browser.
