I packaged the CesiumforUnrealSamples project on Android and found that The latitude and longitude will rendered like a “black line”
Hello @uujk001,
Thanks for bringing this to our attention. To confirm, did you use the latest version of the Cesium for Unreal plugin when you packaged this project? If not, can you try again after updating the plugin?
-Alex
Thanks for your reply. I’m sure I’ve used the latest version of the Cesium for Unreal plugin, but it doesn’t work. I tried installing on several different android devices and they had the same problem
Hi @uujk001,
I’ve created an issue to track this here: Large seams appearing on globe when packaged for Android · Issue #913 · CesiumGS/cesium-unreal · GitHub
Are you using UE4 or UE5?
Alex
Hi, thank you for your attention. I am using UE4 and I will try to package with UE5 next.
I found the same problem using UE5.
